Per Anders: Instead of the Jung regulator, where the zener is de-noised by re-use of the main regulator, why not make a small pre-regulator just for de-noising the Zener?
After the Zener (LM329) can use a direct (better) coupling between opamp and series reg transistor. I think it would be better, and today there is really no reason to save the few bucks, it makes the Jung regulator cheaper, instad of just using one more regulator.
Please comment 🙂
Lars
Below an experimental board with this kind of reg. Didn't get the LM329 in yet ... (so the test board is fitted with a normal -more noisy- zener).
Please comment 🙂
Lars
giolight said:here voltage on the 317T with load: Vin29,3- Vad.24,4- Vout25,2
This Vref is 0.8 V which is too low so the reg attempts to increase the output voltage to try to raise the Vadj. In this situation I would expect a higher Vout, like 28V or so. Hmmm.
Could it be that your resistor divider from Vout to Vadj and Vgnd is incorrect? Or maybe you have a large (leaky) cap across one of those resistors? What else is connected to that Adj pin - diodes?
Jan Didden
the resistor from Adj pin to ground is 1K as is from Out to Adj. The cap from Vadj to ground is 47mF as is in the schematic. The voltage stated in the post above refer to the pre-reg loaded with the reg. and the reg loaded with 10K resistor. I have mounted six positive boards and all measure the same with few millivolt difference.
Giorgio
Giorgio
I'm not totally sure what you mean. Could you possibly draw some?Lars Clausen said:Per Anders: Instead of the Jung regulator, where the zener is de-noised by re-use of the main regulator, why not make a small pre-regulator just for de-noising the Zener?
Please comment 🙂
Do you mean that the reference voltage has it's own stabilized voltage?
So these boards are now history?
Can anyone suggest other options for a good regulator? I'm bummed that I missed this group buy. Darn!
KT
KT
HI,
I finally have a built up version of the regulator working in my cd player. Boy, I left these to the side for so long. I am using the 5v version to power the digital filter in my cd player, the results are good so far way more low level detail and smoother highs., I'll need more time to fully evaluate though......
Next up I will be supplying the dac's with their own super reg supplies, 5v version.
Also a question for Andy, remember I mentioned a use for valves? I would like to try the reg's on a dht stage on my cdp for the filament supply. Trouble is the output required is only 2.78 volts, I assume this is too low for the TL431? Can you suggest a suitable part please?
Raja
Raja
Don't think 2.78 Vdc output voltage will work.
Remember this output voltage is also used to power the opamp; 0-2.78V isn't a lot for an opamp to operate on...😱
boards for sale ?
Is there a source for these regulator boards at this time.
Can someone produce a new batch for us hungry newbie consumers
rbroer said:Don't think 2.78 Vdc output voltage will work.
Rudolf,
In this case one could power the error amp from the unreg input voltage (possibly via a prereg). The same with the reference, which could be divided down with two resistors. Alternatively, use a standard 2.5 v ref as used for DACs, AD has many in their inventory. That should work.
Jan Didden
PS Nice avatar.
Low voltage _may_ be accomplished by some good Rail-to-rail opamp, TLV431 (1.2 volts) or some other 1.2 V reference and suitable gain.Raj1 said:Also a question for Andy, remember I mentioned a use for valves? I would like to try the reg's on a dht stage on my cdp for the filament supply. Trouble is the output required is only 2.78 volts, I assume this is too low for the TL431? Can you suggest a suitable part please?
Raja
I have tested -3.10 V with the following config:
BD140
BC550C
AD825 with gain 2
LM337 with gain 2
Voltage reference red LED 1.55 V
Red LED as voltage shift for the AD825 output
Output current 300 mA (10 ohms load)
Works good, but I haven't tested with + 3.3 V.
I notice that AD825 seems to work far below 6 V which is drawn in the diagrams.
BD140
BC550C
AD825 with gain 2
LM337 with gain 2
Hi Per,
You're right, it might work.
Looking in the AD825 datasheet at the +5V/-5V specs, it seems the output voltage swing is limited to the rails minus about one Vbe drop.
Using a LMx85 for reference and voltage shifter (or 4148 diodes) and a gain of slightly over 2, it might work.
AD825 will have degraded performance at this low supply however.
It's very possible but not DC wise. I get more than 5 digit precision from zero mA to 300 mA.rbroer said:AD825 will have degraded performance at this low supply however.
Thanks for the responses guys.
I have found plenty of opamps that work well down to 2.5v or so, so I don't think that's a problem. There are many 1.2 volts references too. so I assume I can just use a good 1.2v reference and I should be ok........
Raja
Raja
I have tested positive voltages also.peranders said:I have tested -3.10 V with the following config:
BD140
BC550C
AD825 with gain 2
LM337 with gain 2
+5 volts out
D44H11
BC560C
AD825 with gain 2
LM317 with gain 2
LM431 set at 2.50 volt (via 330 ohms)
Output current 500 mA (10 ohms load)
Output was was 5.008 V. Good regulation
+3.3 volts out
D44H11
BC560C
AD825 with gain 2
LM317 with gain 2
Red LED at 1.65 volt (via 330 ohms)
Output current 330 mA (10 ohms load)
Output was was 3.31 V. Good regulation
In both cases the AD825 was fed from the output.
From what I can judge the AD825 seems to be a very good choice altough not very "low cost" as Analog put it, more like rather high cost but also very good 🙂
peranders said:
I have tested positive voltages also.[snip]
Per-Anders,
If you say "tested" what does that mean? Did you look at, say, Zout vs freq, or just that it basically seemed to work?
Jan Didden
I have used a voltmeter and an oscilloscope so it's not thourougly tested. I'll imagine though that the low voltage versions will not be as good as the high voltage ones but it's possible I think to improve the behaviour with carefully selected low voltage opamps.
Wow, still activity here!
Hi guys,
Nice to hear from the latecomers to the build, especially Raja's heart-warming comments about the sound !
For those with problems with the pre-reg voltage (e.g. Giolight), change R2 / R3 to 499R.
It seems that on some brands / batches of 3x7's the 1K doesn't provide enough current to operate the reg properly, halving the value works fine, either swap for 470 or 499R or add another 1K in parallel with the 1k's already there.
Also for the 5V option, use the LM336-2.5 in place of the TL431 - this is a drop-in replacement for the LM329 which saves some fiddling the orientation of the TL431 and works better.
For ultra-low V operation some care in biasing would be needed, to ensure the op-amp is operating in the right modes - watch out for example on some rail-rail op-amps, they have a FET input augmented by a bipolar stage, which can bring variations in performance or 'crossover' effects if biasing isn't correct.
Anyone who's emailed me re: more boards, I have some more and will get around to emailing you back soon, but feel free to 'prod' me if you wish, finding time to deal with the demands is often the biggest challenge, especially with the demands of family life!
The regulator has almost no DC response to anything, due to the topology, it's hardly the most important thing for audio though 😉
Andy.
Hi guys,
Andy.
- Group Buys
- anyone interested in a jung regulator pcb group buy?
