Im using the 400 Watt bulb/ballast from Lumenlab, LL Pro reflector, a 15" VGA Monitor, a 220mm rear fresnel, and a 550mm front fresnel, Im also using the 135mm lens from DIYPROJECTOR Company.
Im getting corner to corner focus, and the image is nice and bright, but it seems like everything has a slight greenish tint. All monitor settings/etc are at their defaults.
How long have you been using the bulb ? Is it the 6500k or 4000k bulb?
The 6500k bulb will be bluish/green for around 20-30 hours or so. After that it gets "whiter".
I was using one of their OLDER bulbs... That one was GREEN...
I switched to one of their NEWER bulbs... this one is more BLUE.
Blue is better than GREEN anyday... I suppose.
I still need to see if I can get my money back for the junk electronic ballast I bought from them that blew up after about 4 usages.
