One of Mine has a red bar going vertical through the screen, I tested the electronics with another panel( lcd) and it worked fine so basically I just need the LCD portion and I thought I would ask around here if anyone had a dead panel that I could Buy. Thanks again
OK now the other proxima panels colors are bleeding bad any Ideas? I probbably Just freakin messed em up. bahhhhhhh any insight would be apreciated, The colors bleed if I try to have the contrast at any Decent level.
Proxima 822 problems
I got my panel today and hooked it up and I cannot get it to configure to 2 million colors. My highest choice is 24000+ colors. Any ideas? with it at 24000 +colors it is really pixelated. I am hooking it up using the composite RCA hookup directly into my DVD player. Do you think that maybe if I used the s video portion of it that it might be better? Let me know if anyone has exprienced this.
Thanks a million I really would like to show my wife something better then this that I spent too much money on.
hey JEvans, Hummmmm have you tried to switch the colors in the menu? I tried that and It worked, I would say try all the Inputs and see what happens. I will keep thinking but Im sorry I cant be of much more help. Someone here prob has more Ideas.
proxima display
Yes I tried to switch display settings and it will only display 24389 and 3373(or something like that) and 8. I have tried the composite rca and the VGA cable to a laptop with a dvd player same results. I hope I did not get burned. anyone have any ideas?? Video does your panel actually say 2000000 colors?
I wonder if I could contact proxima or infocus and maybe they might know what to do. I know it is old so they may tell me to take a hike. Thanks Video
I contacted Proxima they seem to think that the 24000 colors it is a software issue. They dont have a copy of it and neither doa number of other places including projectordr.com which is the company that replaced proxima. and none of them have the software. I guess this is just a loss cause. Let me know if anyone on here has something that might make this panel work.
Hey VF,
How did you test your electronics portion of your 822C? I have one that powers up and shows the Ovation startup screen and menus, but doesn't display anything from the inputs (Composite, S-Video...). I had to make a power supply from an old AT PS... If I can't get this panel fixed I'll have to sell it as junk...
Thanks,
Natekco
I'm new to DIY and learned everything I know from this forum!
Thanks,
Natekco
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Anyone have a broke Proxima 822C
