Anyone ever modded a Dreamcast for audio ?
I've just aquired a used SEGA Dreamcast console for £13, no cables or anything, but I'm planning to convert it into a CD/HD/Network based player that will play MP3, Vorbis, FLAC and others.
For those who don't know much about them, they are based around an Hitachi SH3 CPU, 200MHz, and a custom Yamaha sound chip that is an ARM7 cpu also. Sounds pretty ideal for decoding 🙂
I'm just wondering if anyone has looked into getting I2S or S/PDIF out of the thing, as i'm planning to rebuild it into a seperate box, with a seperate DAC stage fed from a linear supply instead of the switchmode one currently inside it.
In case anyones interested, i suspect not :bawling:
I found the DAC on the PCB today, it is a TI/BB PCM1725 that takes in "Standard" 16-bit data in 3-wire format. Should be trivial to replace this with any DAC of my choosing 🙂
Planning to put this in a box with a new PSU (the one i bought for £13 had a dead switchmode supply), LCD screen, hard disk. Perhaps also make use of the well-made-looking Yamaha GDROM mechanism for a cd drive. The ultimate music storage device 🙂
How do you plan to add a hdd to the dreamcast? There is no interface
There is actually 🙂 The modem port on the side is just a general 16-bit bus. Some guy called bITmASTER designed an interface a while ago
http://www.syncscroller.net/dc/dc-ide.pdf
I read a site where they have improved that interface a bit, the main change being they have discovered how to use a real interrupt to increase performance. A Japanese guy already has the interface working under NetBSD.
I plan to extend the interface logic so I can attach peripherals such as the LCD screen to the bus too.
