I've got one ordered, and wanted to get peoples thoughts on it. (and yes, if you couldnt tell by all the questions I've had and have been posting, I have alot of ideas in my head)
AFAIK LM4652 is only a power MOSFET follower, intended for usage as an output stage of classD amplifier.
Pedja
Pedja
I have both chips on the way. I was interested more in if a simplistic GC type layout could be used, or if the schematics on National's website is the one that has to be used.
In order to succeed you must have a good pcb and also filters at the output. Maybe you have read elsehwre about how much RF pollution those Class D produce?
I say that NS suggestion is a good start.
Re: re😛CB
Yes, and this seems hard to come by, also the gerberfiles and/or pdf's.iceman said:There is a pcb-layout in the data-sheet from NS.
- Chip Amps
- Anyone build a GC sub amp with a LM4652TF?
