Anybody use 841s(VT-51)?
I just bought a bunch of 841s and was planning on using them CCS loaded to develop some serious voltage swing. My goal is to get over 200Vrms with low distortion.
I am going to drive them with a source follower at 400V on the plate (800V supply). If the curves in the datasheet are representative they should work well for developing a lot of voltage drive into a high impedance load at low distortion.
I was just curious if anybody has used these and what your opinions are?
Also, I want to make sure that I don't violate the minimum grid bias resistance but can't find that spec. I am planning on using a 15K resistor for the load of the source follower that will drive the 841. Does that sound reasonable?
Hi!
This is an interesting tube, I also plan to do something with these some time. I only need to find some good ones. Do you have a source where I could get 4-6 pieces?
I would use them in a DHT phonostage 🙄
Just be aware that they have a very high rp, so they cannot drive a lot. Not really suitable for driving a power tube.
Best regards
Thomas
