Hey, I'm looking for a speaker set with these parameters:
Big woofer - 12" would be good, a midrange speaker, and a tweeter. Does anybody know of a site or something with a project like this in it? I just haven't been able to find anything with quite that set of features.
Also can anybody recommend a good book on speaker design? I don't need anything too crazy intense, just a good resource.
Thanks!
Thanks!
Let's keep it simple, and let me try to help if I can.
Those are not parameters.
That's a guess about what might sound good expressed in extremely general terms.
The problem is that the generality is so great that it has no real meaning.
You could have a 12" woofer in a box the size of a refrigerator or in a "bookshelf" sized box, both properly sized depending on the woofer's parameters - and your goals.
FYI, the size of the woofer does NOT in and of itself determine the "bass". For a given size box, a smaller woofer can and often does produce lower frequency bass, while the larger one might play marginally louder - which is usually unimportant.
Suggest you find Parts Express on-line and build a pre-fab design that they sell. That way you don't have to learn about speakers, you can just enjoy the mechanics of building and the the listening.
That would be easiest and best if you want a speaker that you can use and don't want to buy a commercial product, or learn how to DIY one yourself.
_-_-bear
_-_-bear
The more common approach nowadays is to split a big woofer into
two drivers allowing a narrower and more room friendly cabinet.
a couple of 8"ers are ~ equivalent to an 11" driver.
e.g. http://www.htguide.com/forum/showthread.php4?t=22393
/sreten.
/sreten.
Parts Express has a lot of DIY speaker projects. Maybe one of these will work for you.
http://www.parts-express.com/projectshowcase/projectindex.cfm
So does ZillaAudio.
http://www.zillaaudio.com/diy.htm
And so does Planet 10.
http://www.planet10-hifi.com/
Maybe one of these will work for you. There are plenty of other sites on the web as well.
Enloy,
Mike
So does ZillaAudio.
Enloy,
Mike
