Adcom GFA-555 power amp (attached ZIP) question.
Looking at this schematic I don't see D.C. Blocking caps between transistors. I'm coming into Solid State from really not much knowledge of Transistor Amplifiers. I have had classes on Electronics which discussed BJTs and FETS etc on a component level. But I know very little about the application.
That said, I've worked A LOT with tube amps and have experience there. In a tube amp the next stage has to be coupled by a coupling cap which blocks the D.C.
Where are they at in this Adcom schematic? Why doesn't it need them?
Lastly, is there a good place to learn the basics about solid state power amps on this site? (Wiki, FAQ, etc?)
thanks!!
thanks!!
Audio design handbook and Self on audio....
http://books.google.com/books?id=BRQZppvawWwC&dq=self+audio+amplifier+design&printsec=frontcover&source=bl&ots=qtsKFTz4Vk&sig=BJetUpp9X36Vg4EqBcELHsGrPLs&hl=en&ei=MtoCSt_VFoGltgebx9maBw&sa=X&oi=book_result&ct=result&resnum=2#PPR5,M1
http://books.google.com/books?id=oido-UMWNZIC&dq=self+on+audio&printsec=frontcover&source=bl&ots=Gh1dZr70xS&sig=43yppxAYkEZ1GnwLEPqZQJEVwE4&hl=en&ei=_tgCStXUE53Ftge7x7iDBw&sa=X&oi=book_result&ct=result&resnum=4#PPA10,M1
Rod elliots site...
http://sound.westhost.com/
Read and understand these , you are half way there.. 😀
OS
Rod elliots site...
OS
