Hello
I have a Cambridge Audio np30 streamer and a slow internet speed. Syncs at 2mbps with noise of about 6db. Problem is it buffers quite alot on 320k bps streams like bbc radio 3 which make it almost unuseable. On the other hand my thin client running daphile gets away with 320k streams almost faultlessly.
Would it be possible to add a buffer to improve the np30.
Any ideas please.
thyristor44
Any ideas please.
thyristor44
No its on ethernet, Wifi was much worse.How is that np30 connected to internet? WiFi?
Then there's no simple solution, unfortunately... apart from maybe prioritizing ethernet packets per switch - port that has the np30 hooked-up, if your router has that option and if you have a fair few hosts that share the bandwidth. But, you will see minimal improvements, if any...
However, if you have a network hosts that use audio and / or video streaming, than by default, those packets will be prioritised!
To be sure, disconnect all hosts from the router, except the np30 and see if that makes any difference...
Thanks, I will have to wait untill the telephone line is upgraded.Then there's no simple solution, unfortunately... apart from maybe prioritizing ethernet packets per switch - port that has the np30 hooked-up, if your router has that option and if you have a fair few hosts that share the bandwidth. But, you will see minimal improvements, if any...
All the best
thyristor44
No it has trouble, I only have it and the laptop on line and the NP30 on its own struggles. I do have a rotten connection, at the moment 1792kbps. But my daphile music server can stream 320k bps as it has a buffer apparently.
- Digital Source
- Any way to add a buffer to streamer
