Any thoughts on Faital Pro HF200 vs HF204
Okay, I've more or less decided on (polymer diaphragm) Faital HF204 or HF144 (If I decide to use a compression driver over a cone).
That said, I came across this press release. Does the 204 really have the capability to go significantly lower than the 144 or is this merely marketing fluff ? http://www.faitalpro.com/en/press_&_media/news_archive/article/pdf.php?id_article=58
The two drivers even share the same diaphragm !! FaitalPRO RK HF144/146/204/206 1.4"-2" Replacement Diaphragm 8 Ohm
