any question...some questions?
So many variables and unknowns, a bit like I have some shoes where should i walk ?
a 2n3055 is a readily available TO3 as is a MJ15003 PSU Voltage ? Topology? Current Bias? Differential pair ? Opamp ? You could study many of the fine Solid State Amps published at DIY Audio
A simple L pad arrangement resistor preamp usually works straight away.
Cheers / Chris
