Dear Sir,
Could any one tell me is there any Transmission Line horn design (or pipe) that is suitable for FE208-Sigma. It is use within a study room with area of 120sq ft. I like listening to classical music and vocal. My amps in use are 30W EL34 and single end tube amp of severl Watt power.
Thanks for your help.
Zillaspeak has modelled BIB for a wide range of FR drivers, including most current Fostex.
http://www.zillaspeak.com/bib.asp
This design falls within the BLH /TQWP "family", and while they tend to be rather tall for the larger drivers ( 80" or more), the foot print is about as small as you're likely to find for the delivered frequency response.
120sq ft is fairly small space and even with an enclosure that fits the room, you could easily run into some room acoustic problems below 100Hz . Adequate power shouldn't be an issue.
you can look at this...
have a look at Onur Ilkorur's Singular design and ask him if this will work with the 208. You can find information on this cabinet design at Onur's site. Regards Moray James.
http://www.yildiz.edu.tr/~ilkorur/aer.html
If its the FE208 Sigma, the older model with the whizzer then Scott gave the dims for a BIB here in post #1181.
http://www.diyaudio.com/forums/showthread.php?postid=990223#post990223
