I agree with the assessment that the price asked for a set of "Deuce" transformers is nucking futz. 😡 A complete, unrefurbished, "core" should not cost that much.
The O/P transformers used in the Cit. 2 and the Heath W6M are very special and I don't know if satisfactory "clones" of either can be purchased. Good O/P "iron" is always EXPENSIVE.
Maybe you could make something loosely based on the Heath W6M around the Plitron PAT-2100-SSCR O/P transformers, whose full power bandwidth is excellent. Even though the "finals" operate in UL mode, g2 B+ gets regulated for superior open loop linearity. Williamson style circuitry has plenty of NFB, for a decent damping factor. FWIW, I would use a "high" current/"low" plate voltage KT88 operating condition set, to compensate for the comparatively low primary impedance.
BTW, I would adjust the W6M's small signal tube lineup/circuit details to make the gain structure compatible with unattenuated 2 VRMS I/P signals and more linear.
my experience so far with regulated G2 has been very happy indeed, to me they sound better than ultralinears.....thanks for the post, i also like the "high" current/"low" plate voltage KT88 operating condition set.......
Michael Kelly of Aerial recommended years ago the Audio Research VT 130 as a suitable tube amp for the 10Ts.
The 130 has 110 watts per channel continuous at 16 ohms.
Audio Research VT 130 parts list:
http://www.audioresearch.com/ContentsFiles\VT130 Svc Manual Sch PL.pdf
Where do I get the transformers?
Even if you can buy the transformers from ARC, they are going to cost you an arm and a leg... For your $1k budget, I think you are pretty much stuck with off-th-shelf xmfr's from Hammond, Edcor and Heyboer. For the PCB's take a look at Pete Millett and Tubelab, they are proven designs and offer relatively low cost solutions.
Oh NOOOOOOOO...😀
Velleman nv - Item - Details - K4040
Case and everything all done..I know a few people that have used them for the last 10 years..
You can bias double and tube roll as well..but its only 95Watt per channel..tusk tusk..
I,m not happy I want the other 5 watt per channel ...😀
But you get everything..I don't care its only 95W per channel...LMAO Power Tx output Tx and everything..Huh I have to add a switch for U/L and triode..
M. Gregg
M. Gregg
tubes4hifi.com has M-125 ( 125 w monoblock, a pair cost usd1750 )
Is this it?
tubes4hifi amplifier KITs page
M.Gregg
I didn't know they were that expensive... if it was up to me, I would spend a bit more and just get an used Musical Reference RM-200 Mk II. But both options are way above the OP's budget.
Yes.
Good documentation, forum and email support.
If 4 tubes are installed 120w, can be used with 2 tubes ( 60w)
I remind everybody that the OP's speakers require both a substantial damping factor and a high current, SS rectified, PSU.
The Class "AB2" Williamson arrangement of the Heath W6M should meet those needs. Make the PSU "beefy" and tweak the operating conditions of the "finals" to make the speakers play WELL. The speakers are driving the amplifier decisions. The behavior of those speakers seems to be more or less along the lines of AR3s and AR9s. Wimp amplification need NOT apply.
Plitron's PAT-2100-SSCR is expensive at 441.63 USD/Q1. IMO, the "best" way to buy that "iron" is as a group. The price comes down to $382.03 each for 10 pieces and additional per trafo discounts are available at higher volumes.
It would be interesting to find out what's the damping factor, current, etc. of the ARC VT130. That's the amp that Aerial was using years ago for the 10T demo at a show. There is one on ebay sans front plate for $2,599.
None of my current PC boards meet the power requirement, although I am working to fix that! For this reason I mentioned Pete's Engineer's Amp. he specs it at a conservative 18 WPC.
Pete's Engineers Amp is adaptable to 100W/Channel. Several people have pushed it beyond that.
Being an engineer, I bought one of Pete's boards and told him that I would be disappointed if I didn't get at least 50 WPC. That took about 10 minutes (different transformers). I tinkered with the amp off and on in my spare time until I was getting an honest clean 250WPC and 300 WPC at clip. I even paralleled both channels to get 504 watt, with 525 watts at clip.
I then published the recipe for a 125 WPC version that has been built by a dozen or so people. See this thread
http://www.diyaudio.com/forums/tube...ower-amp-design.html?highlight=push+pull+6jn6
Jump to post #438 to see the super sized version in action.
Realistically to get 100WPC from ANY tube amp you are going to spend most of your budget on transformers. The Edcors needed for a 100 WPC amp will cost about $400 including shipping to Florida. Plitrons......well there goes the kilobuck.
According to Pete's complete bill of materials the price for the kit is $326.34, excluding chassis and shipping.
There are some really nice 100 watt Hashimoto's on ebay right now.
2 PP 100W Tube Output Transformer KT88 EL34 KT 88 | eBay
Just thought I would throw that out there.
- Tubes / Valves
- Any plans to build a 100W per channel power amp?
