I am very partial to Electra-Print transformers. They are all hand-wound and don't cost that much more than some of the machine-wound mfg. IMO they are quite simply the best transformers I have ever used. The last set I used (for a PPEL84 amp, actually...) were -1db from 17hz - 55khz!!!
Electra-print.com
You can always use Sowter for a domestic offering, but they are pretty pricy -
sowter.co.uk
People are usually quite happy with Edcor
edcorusa.com
And there is always Hammond from Canada
hammondmfg.com
As for circuit, I have built Morgan Jones' 'Bevios Valley Amp' three times now and each one is wonderful.
The (first) amp shown here is very similar - PS-4 & PS-5 Tube Power Supplies
Electra-print.com
sowter.co.uk
edcorusa.com
hammondmfg.com
have a look at Bluebell Audio based in scotland, Philip supplied Hammonds for my Tubelab Simple PP build, very helpful guy,
simon
simon
P2P vs. PCB
PCB's are handy/easy to stuff, but lining up the PCB mounted tube sockets with the chassis holes can be a PITA if you want the PCB under the deck and the tubes on top. If you "hang" the PCB from under the top deck, you also need to get the standoff height dialed in.
Oversized holes in the top deck make alignment less critical, and allow for some cooling.
another uk source of transformers 'Vvt Ltd' design and make Wound Components including Transformers, Chokes and special Coil Winding.
simon
simon
Tubelab Simple SE
Excellent design that you can customize to your heart's content. Lots of support on the forum.
A new kit that looks promising is KT88 SE Complete Kit
You could look at this little kit based off Jef Larson's (Abraxasaudio) design.
The Spud Kit - $325.00 : Zen Cart!, The Art of E-commerce
- Tubes / Valves
- Any good tube amp kits for a first attempt?
