Go as far as the Group Buy section...
http://www.diyaudio.com/forums/group-buys/167414-reference-tda1541a-dac-i2s-bus-architecture.html
Hi Joshua,
I personally would suggest the boards from ecdesigns. While in many areas relying on somewhat different detailed technical solutions, John Brown's design goals and aims resonate closely with my own. I would expect his board to perform as well as the CD-77.
All of the e-bay kits that I have seen have severe design flaws.
The groupbuy PCB Set is in theory better than the e-bay kits, but the PCB implementation is severely flawed, I would suggest fatally so. The layout is even more inappropriate for high speed mixed signal use. and while the powersupplies on the paper are very good, they way they are implemented will make them mostly worse than a simple 3-pin reg right next to the IC's.
The "reference" in the name seems to point to it being a reference to how many group buy kits here are made and how it should NOT be done, that is by using "cut/paste" from a range of disparate sources and mashing it all up in the hope the results will be outstanding.
Ciao T
Is there any good TDA1541A DAC kit, on eBay or elsewhere?
Ciao T
Good to hear that... 😉
Since ecdesigns' latest boards are only DAC module with a card reader, I'll need a good quality SPDIF to I2S converter.
Yes, that or a USB to I2S interface. Any Async one should do well once you get the clocks improved, ecdesigns boards already have the reclocker...
Ciao T
Ciao T
Cirrus Logic SPDIF receiver. I suspect you could do worse in terms of jitter rejection, but not much.
You would be much better off using your CD-777 as DAC, TBH.
It is better than most generic TDA1541 stuff and it can handle all input sample rates between 44.1KHz and 192KHz except 176.4KHz via SPDIF (this is not officially supported BTW and some over/upsampling modes can create havoc if you use this with > 48KHz sample rates, USB is 48KHz max).
Measured Jitter is quite low (if you do not mistake Tube Stage noise and some very low level hum for jitter, as the editor of a famous UK HiFi rag did...), in the 250ps Peak-Peak and less than 50ps RMS, if I calculated and remembered right.
Ciao T
How about those: S/PDIF 4:1 Receiver/MUX Module , The S/PDIF Transceiver Module ?
Ciao T
Hi Joshua,
Ciao T
If this is the case what if any DAC kit or a ready assembled kit could you recommend? please.
Hey Thorsten,
I'm not sure if you noticed but the second SPDIF transceiver on Joshua's list uses the Wolfson WM8804
Jeff
Jeff
For TDA1541 I gave my recommendation above. The Borbely PCM1704 DAC was pretty good. The various buffalo variants appear very good (not tried).
Most of these Chinese kits are worse than the GB's here, often the design is faulty added to poor parts quality. And from what I see, there is not much that does not fall under "cheap chinese kit".
Best choice may be to buy a 2nd Hand DAC (or CD/DVD/Universal Player) with a good chipset and good basic design (means japanese or US/EU major company) and to modify this suitably.
Ciao T
Ciao T
Also, John's (ecdesigns) super-optimized 1541 board is a bit tricky as it has to be the master. "There can be only ONE!"
This is how he explained it to me:
The MK7 must slave the connected source, so using CS8412 or USB won't
be an option unless the source can be slaved through an extra clock
interlink. CS8412, CS8414 and CS8416 cannot be slaved without loosing
data (periodic ticks in the sound).
Options are using a CD player, tap I2S signals from it, feeding it a
11.2896 MHz clock from the MK7. It is advised to completely remove the
digital filter (SAA7002). Other option is using cheapest squeezebox
player, again tapping I2S and feeding 11.2896 MHz back to the player.
Information of these mods can be found on other threads on diyaudio.
Note that the MK7 bit clock is generated on-board (divider), so the
source only needs to provide WS and DATA signals. This way source
jitter on BCK is eliminated.
Slaving is possible using either async USB (must then be limited to 44.1KHz) or a CDP. Or one can hack Johns work and bypass his master oscillator, or beg him to not include it, so an external MCK may be used, in which case anything goes.
Ciao T
Also, John's (ecdesigns) super-optimized 1541 board is a bit tricky as it has to be the master. "There can be only ONE!"[/I]
Ciao T
Thanks, Thorten.
Any good option out there? Especially SPDIF to I2S that can get it's clock from the DAC PCB.
I do enjoy it very much as a DAC. I'm trying to figure out if I can possibly do any better with the money I have.
Edit,
Oops, you already replied my question.
Don't think that is correct; it will skip or double a sample, depending which clock is faster. Which you probably cannot hear.
I had a china DAC with this type of slaved CS8412. The audibility depended heavily on the music played. I have a CD (rip) I love with only Piano and double bass (Harmon Lewis & Gary Karr - The Spirit of Koussevitsky), it was all but unlistenable, with more pops and ticks than a bad condition LP.
A big FIFO with "re-set" if it is filled with zero's might do the trick.
At AMR we simply stuck in a programmable low jitter clock and appropriate software. It is amazingly effective.
Ciao T
Ciao T
Ciao T
Are there any asynch USB products/designs that would allow slaving to John's module? That would require galvanic isolation on the USB side (meaning RBCD only) but I have not seen any asynch USB1.0 to 16/44.1 I2S, they seem to be a unicorn.
So I think ECDesign's work is that he has created a modern CD player, not a standalone DAC (the title of his thread is not quite there yet.)
Now to the original question, are there any good TDA1541 kits or even PCB's available, and I think the answer may be "no." I'd say there probably isn't even a good open TDA1541 Standalone DAC design because the chip really needs a master clock.
In general DIY DAC builders need a slavable asynch usb implementation that can spit out i2s and all its variants (r justified, 16 bit, 24 bit, split L&R, etc).
Alternativley a for the TDA1541 a project where asych usb is properly implemented on board. Hopefully the widget project or somthing comes along for us non-software engineers who want to build a TDA1541 DAC but understand the importance of it being master clocked.
Maybe there is something out there but I haven't been able to find it. So I think it is a good thing this thread was started.
Any of them? Well, any with discrete Audio Clocks of suitable frequency.
You just need to remember to set your PC or player not to feed them anything else except 44.1KHz.
Why would it? Isolating I2S is trivial, given that most frequencies are quite low.
The AMR CD-77 CAN be used as Stand Alone DAC, so if I may be so bold, there is at least one.
Ciao T
Ciao T
If you are really paranoid with clocks seems to me you would not want an USB-PHY in the dac box as it will need several asynchronous clocks running all the time
A good clock close to the dac possibly with a locally slaved cs8412 with a wclk clock feed back to a computer with a juli@ soundcard would let you have everything synchronous (or better make sure the dac be the only thing changing state half a cycle from everything else) in the dac and use only the absolute minimum chocolates needed and leave the many unrelated and much higher clocks in the pc.
- Digital Line Level
- Any good TDA1541A DAC kit?
