Ciao,
I am considering a EF184 (used as pentode) in a DAC IV-preamp. Bias should be in the 10-15mA/150-200V region.
Does any of you have experience with this puppy in critical low level applications? I used it a while ago as CCS and I was quite impressed by the build quality (I think they were tunsfgram) and sound.
Would you point me to other small pentode that can be biased at that current? I am not used to those tubes, sorry.
Gianluca
Gianluca
The only small current pentodes i use are E180F/E280F/D3A. Very suitable for low level signals and work at similar currents. Higher transconductance than EF184. Out of curiosity: why as a pentode? Voltage gain is sufficiently high as triodes and you won't need an extra stage to get acceptable output impedance.
I can vouch for the D3A, very quiet in general.. For this application I would think triode connection would be fine.. The tube has a mu of 77 and an rp that is <2K IME.. Who needs pentode partition noise in an application like this? (I am not sure how big an issue it would be, but as a pentode connection is probably not required....) Ideal for a single stage low noise amplifier with low output Z. Use a CCS or choke load and it will drive a 10K load quite happily..
I'd like to use it as current to voltage device not as a voltage amplifer. D3A can be quite expensive maybe??!!
GG? Hum... yes actually. With a servobias. It seems it works pretty on spice and as I have most of the parts (but the EF184) I'd like to give it a try.
Is a guitar amp a critical low level application?🙂Does any of you have experience with this puppy in critical low level applications?
Can't help you with your project, all I can say is this tube sounds great. Geek knows this too.
When I was looking at the build quality I thought: thanks God there are plenty of NOS available.I was quite impressed by the build quality
The EF184/6EJ7 seems to have a favorable opinion even though its considered a "tv" tube. The price is low so give them a try.
It should work if implemented properly..(Common grid from an AC standpoint, dc servo bias applied to grid) 😀 Gain may be insufficient with some dacs, as you really want close to virtual earth behavior at the input, however a 1:2 step up transformer (triode connection only!) will generally remedy that at the expense of rather higher output impedance. (Like 4 x rp) Perhaps a high transconductance pentode used as a pentode is the way to go with an output buffer of some sort. Can't hurt to try it. (which I haven't)
You ought to post your proposed circuit.
I will. Let me build it and see if it is worth something.
Gianluca
- Tubes / Valves
- Any EF184 users?
