https://www.parts-express.com/B-C-ME90-1.4-Constant-Directivity-Horn-80x60-4-Bolt-294-626?quantity=1
There‘s a used pair on a local classified for cheap……worth grabbing to see how they play?…..I like the dispersion pattern for my family room which has a a ramp ceiling from 8 to 12ft.
Good pattern control to about 1000 Hz, worth a try. Do you have drivers or do they come with them?
https://audioxpress.com/article/test-bench-b-c-speakers-de990tn-compression-driver
Will sound "dull" without HF compensation, but that goes with any "constant directivity" horn.
Those horns take a 1.4” compression drive. Most compression drives have either a 1” or 2” hole. You will be very limited in your choice of drivers
Currently, B&C offers twenty different 1" exit drivers, twenty different 1.4" exit drivers, and only nine 2" exit drivers.
The trend carries through with most modern driver manufacturers.
