Just a quick question,
Has anyone had experience using ansar caps in valve signal coupling
compared with something like the Obbligato?
Just looking again at the low cost caps..
M. Gregg
M. Gregg
I guess no one has used them,
I have no connection with this company, however I find some of the information interesting..OK some of it is debatable information. (The aging linked to voltage proofing is interesting)
I guess I'll have to see..🙂
Link:
Ansar Capacitors Technical Information from suppression-devices.com
M. Gregg
Link:
M. Gregg
I have used them - but not done much comparison.
The CPA series 5uF 10uF 400V work well in my crossovers, and as B+ capacitors in circuits which do not circulate signal current in the supply capacitor (shunt cascode stages).
I could not detect any dramatic difference between CPAs and LCR AG series, in B+ circuits.
I have more extensively used LCR AG 1uF & 4,7uF for caps just after the rectifier in quasi-choke input supplies. I think these are top flight in this position - HUGELY better than motor-run MKPs - which sound very poor to my ears.
Now, LCR have acquired the AMPOHM product range, and their FP-CA-AU 30uF 630V MKP audio types are worth the cost. Use in cathode bypass and B+ caps.
LCR Capacitors - Capacitors and EMC filters
FP-CA-30-AU - AMPOHM WOUND PRODUCTS - AUDIO CAPACITOR, 30UF, 630V | Farnell United Kingdom
I have always liked Ansar as one of the better sounding of the inexpensive polyprop caps, I generally prefer them to Solen. They also respond well to bypass with a small value Hovland or similar.
I normally get them from Cricklewood
Cricklewood Electronics
I can't offer any advice on LCRs as it is too long since I last tried them, but it looks like they are worth a go.
ICW is the other UK made range, and their Clarity Caps have a good rep, although I haven't tried them
Clarity Cap
Clarity Cap
I use the Clarity SA in my XO, and the ESA as supply caps in some of my audio equipment. The SA was huge step up in the cross-overs compared to the Solens they replaced - more detail, and a much cleaner sound overall.. I was a little surprised actually as I expected very minor differences at most. They aren't expensive relatively speaking and offer a lot of bang for the buck.. (quid 😀 )
The ESA are in locations (inside the driver stage output current loop of my amps) where they are audible and they were a significant improvement over anything I had tried. (I do have them shunted with smaller Kimber caps as well.)
Well,
I have some Ansars on order..I want to try them.. as you do..
Yes just a few quid... 😀
M. Gregg
M. Gregg
- Design & Build
- Parts
- Ansar caps
