Another proac 2.5 clone project!
Here are my pics about this speaker project, which sound such beautifull as it looks like. 🙂 The best thing is, that you can not stop listen this speakers. If anybody got some question, just go ahead.
How much damping material
I have seen quite a few pictures of ProAc clones. Some seem to have very few damping (I would say about 3cm). Others like the pictures on this thread seem to have quite a bit. Is it very important to stay to specs of 5cm of damping? Is density of the material important? What would be the sonic differences.
Cross-Over modifications
Supernet,
I suppose that you used the notch filter of Troels. Which version did you use. His latest posted on in Dec (v4) or the version of October (v2)? I listen mostly to classical myself and I like a very neutral sound.
bitumen
I am building my ProAc clones, and I am planning to use roof insulation kind of bitumen plates, something like this.
I heard that "ordinary" bitumen can emit gases which can damage the speakers. Is that a big threat for me? Should I use something else instead?
Saci
Re: bitumen
Hi Saci
Yes, the bitumen may outgass solvents that could affect your drivers.
What I have done in the past was to install the bitumen sheeting and do any final staining/painting/varnishing, and then move the speakers into a warm room for a few days. When you can no longer smell any solvents, then you should be able to install drivers and crossovers. The bitumen will continue to outgass for a while, but as you have a ported box it will not build up into dangerous levels, especially if you keep running the speakers, as the airflow through the port will ventilate the box quite nicely.
The emited solvents are heavier than air, so will tend to collect in the bottom of the box as well, so if your drivers are at the top, and the ports at the bottom, you should have no problems at all😉
