Assuming I'm aesthetically set on a 2-way smallish tower with one or two 5-7" woofers, is there and reason NOT to build a transmission-line style speaker? What are the potential drawbacks of MLTLs? Something like this from Troels Graveson.
Cabinet complexity (within reason) is not an issue.
Note: Just to be clear, IME the cab's axial length must be > 36" to qualify as a MLTL, i.e. its TL action either shortens the vent and/or allows a bigger one for a given tuning, otherwise just slim BR
Just stumbled on this today…
http://www.quarter-wave.com/Project13/Satori_TL_Design_Documentation.pdf
Seems wild. Very-well documented 8” woofer in a two-way TL! Thoughts?
A typically well-designed project from Martin -I'd expect no less. If I was nit-picking, I'd prefer a bit more suppression of the woofer's stopband modes in the 3KHz - 5KHz region (passive or active versions), but he's done a good job with very few components, and whether you'd hear the difference is debatable anyway. You could do a lot worse.
