Sun Valley SV-Pre1616D
WE will start to accept pre-order in Early August
- 12 AX 7 JJ ECC 82/12 AU 7
- 12 AX 7 GD 12 AU 7
- Mullard CV 400/12 AU 7 (3 matched) SOVTEK 5 AR 4
You can use the following combination
① 12 AX 7 - 12 AX 7 - 12 AX 7 (Sharp and high contrast)
* Standard combination (SV - 722 Marantz type and same circuit)
② 12 AX 7 - 12 AX 7 - 12 AU 7 (Skeletal feeling and entity feeling of medium low range)
* SV - 722 Mckin type sound image Reproduced
③ 12 AU 7 - 12 AU 7 - 12 AU 7 (round and resonate rich)
※ Featuring a rich overtone feeling of the SV - 310 series
Input: 4 lines [Input 4 can be changed to USB input (option)]
Input Volume: Yes
frequency response: 15 Hz ~ 70 kHz (-3 dB)
gain: 15 dB
size: 250W, 225D, 135H (mm ) ※ including protrusions
weight: 3.6 kg
Input Volume: Yes
gain: 15 dB
weight: 3.6 kg
