Another amp
Vivek said:
Lineup, the link does not work.
Vivek
Andy L. Francis said:
The link works here...
Yes, Vivek.
Whatever you do, Never get yourself a free AUDIO website at
a-w-a-r-d-s-p-a-c-e.c-o-m
Marcus 'M250' Gunnarsson did http://marcusgun.awardspace.com/ :(
I also did: http://lineup.awardspace.com/ :(
If you surf:
-> Marcus Startpage -> then elektronik -> then M250 page
..... then you will se images.
http://marcusgun.awardspace.com/index.html
http://marcusgun.awardspace.com/elektronik.html
http://marcusgun.awardspace.com/m250.html
Because the REFERER was his - elektronik.html page.
But if you go from here, directly to his M250 ... you see NO Images.
http://www.diyaudio.com/forums/showthread.php?postid=1561549#post1561549
That is, you can never use those images outside your site
for example here in diyaudio forum.
They have a script.
When this script see that your REFERER is another site (that is where you came from, where you were. where you are)
then they wont show The Image, but show some crazy Advert for their site.
Now, 50 times better host for your free AUDIO website is www.freehostia.com
See for example this website I have .. At least a Startpage:
http://lineupaudio.freehostia.com/
Free Hostia also have no banners ads on your site. ( Like others have e.g. www.geocities.com )
And you can link to your images
Andy. You are right also. If we go via Marcus elektronik.html page his M250 page will work. At least most of the time. If it does not .. you may have to close down your browser .. and try again
hi quasi
without your permission i modified your nmos200 pcb to suit my needs
i will be using this pcb for nmos350 please comment on this pcb
and also please suggest a matchiing pre amplifier based on opamps
i have already made nmos200
thanks for the lovely amp
with best regards
  • nmos too 247 mod.lay].pdf
Re: Commentable Thoughts
Workhorse said:
Ampman States That the M250 amplifier is unreliable amp due to folowing reasons:
1 The input differential is single ended.
2 Shared constant current source.
3 Complementary output stage.
4 Very low current gain of emitter follower stages.
Therfore due to above stated commentations M250 cannot be stated as reliable amp Acc to Professional Standards.
Ampman
That is your opinion, Workhorse.
I know you make great N-Channel HEXFET amplifiers in India.
I love your works, man :cool:
But you are not the only one to make good useful amplifiers.
We can do good DIY Audio amplifiers in Sweden, too.
Don't you think we can?
If not you think, then just build it and listen .....and you see
Lineup
possible causes for distortion
hi all... i built this amp about 9 months ago, and it worked great... untill 3 days ago...
The symptoms, amost halved output power, and some audiable distortion at all frequencies. Ive put the amp through some frequency tests with a cro and signal generator and i can only see some cross over distortion on the output. I cant blame all this distortion im hearing on that can I? i mean it only just started happening, which makes me think ive cooked a transistor somewhere.
anyway, the reason im posting this problem here is because i cant see how a little bit of crossover distortion is making that much difference to what I hear, and also i wouldnt know where to start in removing it.
anyway, im new to this forum (well im an avid reader) so be nice :p.....
k, measured results.
ok, i measured all the Vbe values of all the transistors. Here are the results:
T1-0.6v, T2-0.6v, T3-0.57v, T4-0.6v, T5-0.6v, T6-1.02v, T7- 0.51v, T8-0.54v, T9-0.56v, T10 to T13-0.26v, T14 to T17-0.54v, T18-0.64v
well for some reason the Vbe of T6 is rather high, unsure as to why as that is the shortcircuit protection. Wonder whether that means i have a short someone on the output tracks, will check that later..
As for the main output transistors T10 to T13, seems a bit low. That might explain crossover distortion. But what does this mean? output transistors faulty? something else causing them to become unbiased?
any ideas? still at a loss...
I would definately Suspect problems with T10 to T13.
Since they are in Parallel, It may be only One of these causing the Problem.
And that 1.02 Volts on T6 also seems STRANGE.
You could Remove T10 to T13 and put in Just One New Transistor.
Than test the Base to Emitter voltage of it and see if the voltage is Corrected.
Without knowing your Electronic capabilities, Its hard for me to advise you on trying to test the origional T10 to T13 transistors.
