Hello,
one channel of my Aleph-X running on 25V-0-25V and 6.7A of bias is up and running. I have some problems with my DC offset (0.221V) but I have probably not matched my 9610's correctly. Strangely I did the same procedure for my 'old' Aleph 4 and there it worked out ok (0.03V).
Changes to Grey's circuit (hifizen PCB):
22-0-22 1000VA transformer (gives 25-0-25 DC)
BIAS resistors = 0.56 ohm
R17 = 6k8 (6mA running through zener diode).
R14, R31 = 1k5
R15, R32 = 1k5
R34, R12 = 1K potmeter which I adjusted by hand (ACS gain)
I have adjusted the ACS by running 9V RMS of 1K sine through the amp. I will replace the potmeter with a resistor when all is stable.
I am running without the 'ground' resistors for the absolute DC but I have to let the amp run for more than an hour, but I do not trust him at this stage to run for an hour. It looks to drift and kind of stabilize after 10 minutes (does not drift to fast any more).
I am using 2 times 10W 0.22 (=0.11) ohm for the CRCRC filter.
Here come the first pictures:
It will deliver:
Watts Ohm
124.47 8.50
132.25 8.00
141.07 7.50
151.14 7.00
145.89 6.50
134.67 6.00
123.45 5.50
112.23 5.00
101.00 4.50
89.78 4.00
78.56 3.50
67.34 3.00
56.11 2.50
44.89 2.00
More info to come,
Edwin
R14, R31 = 1k5
R15, R32 = 1k5
It will deliver:
Watts Ohm
124.47 8.50
132.25 8.00
141.07 7.50
151.14 7.00
145.89 6.50
134.67 6.00
123.45 5.50
112.23 5.00
101.00 4.50
89.78 4.00
78.56 3.50
67.34 3.00
56.11 2.50
44.89 2.00
More info to come,
Edwin
O yes,
one question, do you match the IRF9610 on 10mA or on 20mA ??? Because they are running 10mA each, but Mark Finnis his 'old' document mentioned matching on 20mA ?
Edwin
Edwin
That's right, we want them matched to 10mA each !!!
Impressive . I have trouble with an Aleph2 . Please read the thread I started on Passlabs forum too.
Hope you can help...
Edwin Dorre said:O yes,
Edwin
OH YEAH BABY!!! VERY NICE INDEED. Finally someone put the boards to good use.
Never mind the 10ma or 20 ma, you got to measure the voltage on the 390 ohms resistors and make sure it's the same.
Also, the value of the source resistors is really important, did you match those?? They can vary by quite a bit. especially since all bunched up like that they are getting infernally hot and their thermal caracteristics are going to be all over the place
All 0.5W resistors are 0.1% so the 220 ohm's. All .56 ohm are 2% and not matched... On which resistors are you targetting? The output resistors (stay cold) the 0.56 bias (stay cold) or others?
Hmmm... I will look further!
Thanks alot for the compliment!
Edwin
One is 4.63V and one is 4.58V ... not a big difference...
My old 'test' 25W Aleph-X had 4.77V and 4.85V and only 0.048V of offset...
Edwin
Re: Wonderful feat, Edwin!
Thanks,
I forgot to thank everybody who worked on this project; ofcourse Nelson Pass, Grey Rollins, Hifizen, Carpenter and many many others who contributed to the original Aleph-X thread, Aleph-X Highpower thread and the Aleph-X PCB thread !!!
Edwin
carpenter said:I hope your amp brings you many hours of joyful listening.
John
Thanks,
Edwin
Edwin
I have changed the pair but it did not help really. It fell back to 0.101V, but the values of the 390ohm resistors are now about .1V apart instead of the old .05V 🙁
I only get the DC offset away by turning up the left side bias to about .520V each resistor and turning down the bias to the right to about .435V each... Only then is the DC offset about 34mV !
Why o why?
Edwin
Edwin
The difference is 50mV could certainly be better.
As far as the resistor go I was talking about the voltage drop on the .56 resistors? Are they all the same? Any difference there will probably cause the DC offset you are seeing.
Have you tried putting a couple of 100 ohms to gnd on the output to see if it helps? I have many other things you can check for.
PS A little shameless self promotion: I am the "pr" stamped on your board 😉
Edwin
Regular Aleph is different than Aleph X in that respect. Get as close as possible with voltage drop on those resistors by matching input mosfet in a circuit. You can adjust the offset by playing with a trimpot in CCS on input differential (which changes the current).
At least it worked for me.
100ohms to ground at the output doesn't influence the obolute DC offste in any way.
Your chassiss will be pretty deep😉
Edwin,
that's fine no problem. What you are describing is caused by output mosfets that have different transconductance. Nelson has suggested to match the semis at two different current levels to ascertain that the transconductance is similar between mosfets.
I first build a test Aleph-X !!! With this Aleph-X all is well...
Do you mean to change R17 to a trimpot?
Edwin
Peter Daniel said:100ohms to ground at the output doesn't influence the obolute DC offste in any way.
It doesn't at 15 V rail, at 25 I am not so sure. There are different things that happen at higher voltage as I found out. Nelson uses them.
R17 doesn't do anything to the DC, it just control how much current flows through the voltage reference.
Hi, Edwin,
Very nice amp!!!
The nicest way to reduce offset is what Peter says in post #11.
Second, I used the resistors from common input sources to outputs and I set the value at 4.7k. Bringing it further down to 2.2k increased stability of the offset.
Coupling caps at the input also helps a lot, not only for the zero offset, but also for offset drift.
I never used 100ohm resistors at the output and it works great: 1 to 2mV after 10 to 15 minutes, and very stable.
Look at http://www.diyaudio.com/forums/showthread.php?postid=173696#post173696 and you will see how I mounted the input fets; very handy to change them till they match perfectly.
There's also a post somewhere that says to first adjust V1/V3, then V2. V2 has a great infuence on offset.
These are my findings when building the amp.
What value did you use for R19/29 and for feedback and input R's?
Did you use C2/4?
/Hugo - can't wait to see pics of the finished amps. 😉
Very nice amp!!!
Did you use C2/4?
Netlist,
yes, post 11 is all fine and dandy and that is what edwin is doing.
The problem he is having is that he can 0 the dc offset (practically speaking) but that brings produces a somewhat different current flow between the two sides as measured by the voltage drops on the source resistor, that is assuming that all the resistor are exactly equal of course.
Edwin
I don't know your particular setup, but you need a trimpot to adjust current flowing through differential pair. It so happens that by changing that current, you can also adjust DC offset.
The guy's got 5 trimpots, as I can see from the pic. 1 appears to be for the ccs adjustment and an extra pair for r12 and 34 for the AC current gain adjustment.
- Another Aleph-X coming up!
