Cruquius
It should be 50 hz, so maybe they are messing with you. Are you sure the Cruquius is still working and generating 220-230 volts or are they changing it into an American Windmill generating 110-127V @ 60 hz ...
I like it here in Florida, I just wanted the sadness to go away.
All this leaving is getting to me.
X
maybe an aleph-X-ray for you ??
X
I found out my problem of my 5 seconds of humm.
On the picture you see I stacked the toroids on each other.
When connected on the net, I heard a buzzing humm for just 5 seconds and then dissappeared, then 5 seconds later it reappeared.
Then I began to think (harder), and realized the they were wrongly connected on the primary side.
The hum is now gone, I switched the mains for one toriod at the primary side of the connection in the mains.(sorry for my bad english)
Now the hum is gone..,hurraaii
Another thing.., I inserted on the mains 2x17Watt resistors on the fase and minus of the mains, to reduce peak surges.
Works fine for me, since I load for a total of 260.000uF.
Hope this information helps.
Later more pictures for my stereo aleph 60.
I'm still confused about this manual, in the manual it says it consumes about 240Watts, later in the manual in states for approximatly 200watts. What wattage is it? Still a 40Watts difference.
Thank you.
Thank you.
Well actually I live in Haarlem.., but when I say A'dam the people outside then know were I live.
Hello, blank527.
I really do live in amsterdam. This www is getting smaller by the day!
I am very curious to know where you get your surplus stuff from. I have been lookingI got almost anything surplus
Do I see a "draaibank" in your shed as well. Boy you seem well-equipped!
Mostly I go to Muco/Display just around the corner on Bilderdijkstraatdid you get all your parts at Radio Rotor in the Kinkerstraat?
