Hi, looking at some ultra budget android boxes.
F.ex. X96Q pro.
It uses H313 SoC
- https://www.allwinnertech.com/uploads/pdf/2020040917181739.pdf
It supports several kinds of I2S, bit and sampling rates.
But I cannot really understand what audio I can get through a particular implementation (f.ex. X96 box).
What one can get via HDMI, via spdif and via USB (if possible to connect an external DAC).
Also, is it possible to use it as a player over LAN - both for audio and video files on a PC server.
Regards, Emil
F.ex. X96Q pro.
It uses H313 SoC
Regards, Emil
Looks pretty cool for $20, there is an H616 that has a bit more internal memory.
The processing boasts 32/192 audio, but until we know how it will handle usb audio…
It does have emmc memory, so if it doesn’t have the capability as delivered, someone will probably write a modified code for the operating system.
I have a feeling that high resolution audio is going to be very cheap and readily available quite soon.
That's what Apple and other's have been saying for years.I have a feeling that high resolution audio is going to be very cheap and readily available quite soon.
True HD streaming would be nice.
