Anaview ALC0100/0180 comment
I want to build a new amp and I want I to be small(ish) and not to expensive. I came across the icepower amp but are not cheap.
Looking a bit further I found the anaview amps. They are small and do not need an additional power supply etc.
But are these amp any good? I can find some threads but they are about different models and from long ago.
So I am looking for some user information.
I want to drive some high sensitive full range speakers with it. And want to use it with a Mac and a Music Streamer II.
I have a problem with my ALC0100-2300 C. I found that R2601 is burnt beyond recognition, hence i do not know the resistance value to do component replacement.
Can anyone please help me to identify the value or snap a picture of a perfectly functional ALC0100-2300.
Hey Russc,
Thank you. Attached are the pics.
Sorry, after dismantling for photos I realised I have AMS0100-2300, not ALC.
FWIW, photos attached (seen as I'd already taken them).
I can read the part codes easier on the photo than from life even using a magnifier. Not bad for hand held camera, indoors, with no special lighting (and no flash or direct light due to reflections).
