<snip>
Which post of mine are you referring to? It would help if you could quote it.
For example this one:
Analysis of speaker cables
But, I'm sure that your remember having raised the "human head movement problem" in a a lot of other threads as well.
What degree of shift from central is caused by a 5us time difference?
Is I recall, 1 sample of red book CD is 10 degrees. Or was it 20 - significant. Cant find the info source...
What's the minimum delay you can implement with DSP?
1 sample at used FS. One could manipulate the clock phase but it would require different clocks per channel....
The ability of humans to detect interchannel time differences as low as (at least) 10us was long established, therefore quite surprising that the first cd-players only used one da-converter for reproduction.
The MAA (minimum audible angle) of 1 degree corresponds to roughly 10us, but is frequency dependent and sensitivity is best in the frontal median plane.
As usually some distribution exists among humans it is quite probable that some will be able to discern even smaller ITDs.
@Evenharmonics,
it would help if you could cite some relevant literature/studies in which the effects of head motion were examined.
The studies, I'm aware of, so far provided evidence for a unconscious self compensating effect wrt to our head movements.
Beside any illness it is pretty normal for humans to move their heads nearly all the time and if you think about it, this self compensation mechanism makes a lot of sense.
What do you mean, problem?For example this one:
Yes, but the good ones split the L and R in 2 lanes, delayed one of them one sample and clocked them into the DA simultaneously.
So your saying moving a one speaker 2mm closer will shift the image noticable?
Hard to believe.
More thoughts. How does ITD relate to 2 speakers and phantom image. The ITD happenes from both speakers but we hear it as one sound in the middle. So moving one speaker forward doesn't really change the ITDs of either speaker just the ITD between speakers, and this may not be as audible. And it seems that cable dependent ITD is the same as one speaker Moving as not as audible as an actual ITD chage in a mono signal.
I think you are right. I tried to make a similar point earlier when I said ITD is how we locate a single source. Of course we use it to locate multiple single sources not the time difference between two sources transmitting the same information.
Was there any ITD testing done with more than one speaker (not headphones)? Just a hunch but since delaying one speaker is not the same as ITD from a mono source I would say it dosnt relate one to one. How do we hear 2 sources at angels as one in the middle even though theres ITD cues?
Yea Ive always had trouble with the 5us delay of one speaker making any difference. Maybe with headphones. This just feels like another atempt at clutching straws (taking a known effect and using it incorectly) to sell overpriced cables, etc.
I linked to this earlier too Stereo Perception, Sound Localization & Auditory Cues Although we use ITD all the time to locate sound sources it explains how for stereo reproduction using speakers it is largely irrelevant and why panning is used instead. The phrase "inter channel delay" has crept into the conversation at least a couple of times as if it's the same as ITD, I don't think it is.
NO!!! It is absolutely NOT!!!!!!
Love using the caps, make my argument stronger, right?😉
I have detailed what cable "geometry" is needed to reduce ITD variation despite variations in speaker impedance vs frequency vs acceleration.
I have detailed how to spot a sensitivity between cables and speaker impedance.
I have presented a design of cables which alleviates the issue.
My "design" requires quadrupling the number of bog standard zip cables, using #18 or #16 zip cables in parallel to drop the RFZ.
I do not sell cables.
I do not sell anything.
My "solution" does not require expensive cables. And, it requires only a specification of L, C, and R.
....And, I do not clutch at straws.
Jn
In point of fact, my foray into ITD was started because I was unable to get a centered proper lateralization with my headphones. It turned out my computer soundcard had one DAC and two S/H. There was a half rate delay between ears I could not compensate using the pan control.The ability of humans to detect interchannel time differences as low as (at least) 10us was long established, therefore quite surprising that the first cd-players only used one da-converter for reproduction.
Jn
Not sure how to interpret headphone lateralization in degrees. It didn't center in my head. Much of the image seemed to fight against the balance control.
Jn
Jn
Sample rate was 44kHz? What does half rate delay amount to? Perhaps I wrongly assumed it was about 10us, is it 40us? Inter channel delay would be more easily perceived with headphones since ITD is eliminated?
If we agree, that this problem doesn't exist, I'm fine with that. 🙂
Indeed the "ITD between speakers" is the foundation of the socalled "time-arrival-stereophony" and there were quite a few studies examing the effects. Afair, I've linked some in the past but could do again it if there is some interest.
Humans are different and so it is not surprising that some are more sensitive to missing time difference information than others.
For example JJ is on the records that he can't stand listening to records done with pure pan-potting.
It is still a mistery why most humans perceive a virtual sound source in the median frontal plane if both speakers distribute the same signal. And our listening sense has to cope with the fact, that very similar signals are arriving at different times due to the two speaker arrangement, but it is still a pattern anyway. And our listening sense seems to be quite good in detecting differences in patterns, so if in this situation the time pattern changes, it can be detected.
As said before, it is frequency dependent (due to physiological reasons) and usually the detection ability vaires from human to human (due to training, physiological differences and habits).
With 44.1 Khz, each new sample comes every 23usec.
With 2 channels from one DAC, samples come in between, which is 12,5 usec inter channel delay.
However almost all modern DACs upsample to 192 Khz, meaning that the interchannel delay is only 2.6usec.
In both cases I don’t think it can be audible and if so, I strongly suspect other causes like unequal FR of the reconstruction filters in combination with small level differences.
Looking at low cost DAC test, slightly unequal FR and gain is often the case.
Hans
Hans
- General Interest
- Everything Else
- Analysis of speaker cables
