An attempt to diffuse really close to the source
No, I also would not expect quite a such strong signal from edge diffraction. Would any close reflective surface give you that time delay? You could also vary the microphone distance. I make mostly of my measurements at 30cm distance if I want to measure the driver in a room so reflections of wall/floor will be of relative lower level.
free space (outdoors) would be better for what you want to investigate with your measurements
The period 2ms goes down increasing the soundcard level and decreasing the mic gain. So I think is a problem of my poor setup.
Covering the holes with a cardboard sheet, I get :
Yes both in frequency and impulse at 1ms. My speakers have a circular front baffle of 70cm diameter but the drivers are arranged quite eccentric with only10cm space to edge so the distance from drivers to edge varies and I see +/- no comb filtering in the frequency spectrum or no significant peak in the impulse response I can contribute to edge diffraction. There are micro perforated panels used for sound absorbers and they have a quite large absorption spectrum compared to other absorbers but I do not know if they work efficiently if the sound is traveling parallel to the surface. Would be interesting to try but difficult to get (and expensive).
thanks for that link. The reason I find it interesting that it is a fairly wide band low frequency absorber (relative to a classical Helmholz) by itself but combined with a standard absorber (as an additional layer) which does not work well in that frequencies it allows wider band absorption.
I still don't know how it would work at low incidence angle as in your idea.
Regarding the listening, I have the typical endorphins levels of a diyer that judges his artifact.
Regarding the measurements:
two months separate the graphs,
I have no experience in acoustic measurements,
I do not have professional equipment,
... and I'm a diyer who measures his artifact.
However,
the physical bases of functioning exist, even if the proposed models do not consider "holes on the edge",
it is easy for everydiyer to try,
in tiny rooms, a lot of good commercial speakers lean against the wall, too high, with tremendous exits.
IMO
