an absolutelly pass labs off topic
before someone remove this post to solid state may also bother to read it first .....
lets see ... on scope there is an amplifier called BEHRINGER EP2500
more than 50 volts are produced in the out of this amp that is a big number i think so i will consider it as a pro amp.... ( copy of qsc rmx something)
this amplifier is ...
class H ( with the known goods and bads )
sziklai ( with the known goods and bads )
capacitor coupled ( with the known goods and bads )
featuring VI limmiter and electronic input limmiter also ( with the known goods and bads )
now i can hear a lots of things about how good this amp sounds and I also have my personal opinion but there is something that i will not "accept" any argument and that will be that the amplifier is virtually impossiblle to destroy
that is for a number of reasons
capacitors
sziklai
class H
transitors directly mounted on heatsink
limmiters
and crowbar
now from a safety aspect it seems that originally QSC people sit down and think how many available protections exist and apply them all ...now that is realy inovative cause the amplifier is solid rock but doesnt sound that perfect and to my understanding that is very correct marketing wise
there need for the one or the other
now the question is very simple
i wonder if the one and only Mr Pass had a target to produce one amplifier of the range of 250W made for medium Pa use ( all features included = both quality and safety ) while preserving average low cost and simple to make ...
I wonder how inovative this could be
I could almost hear Mr. Pass yawning at the "challenge" from across the continent. Why don't we take a look at what it might take to get to the target with some of his existing designs and add superior sound quality to the design requirements?
some options:
Super A-75. Bump the rails up to around 90V on the outputs (12+ pairs), 95-100 on the front end. Watch dissipation in various front end components. Maybe add cascodes to the front end to keep the input get dissipation down and current up, or use IRF510/9510. Do we want to add VI limiting or just throw a 10A slow blow on the output?
Bridged A-75, pretty darned rugged, but we might want to add protection.
AX100 bumped up to 60V rails and maybe protection circuits added
Any of these options may have to be thermally compensated if operated at lower than usual (for NP designs) bias. I mounted the Vgs multiplier on an output FET of my A-75s and it seems way overcompensated. It takes 45 seconds to come up to the point where it makes sound, and another minute or so bring the bias up to a decent no audible crossover distortion level. Probably not acceptable for PA use 😉
Anyone else want to take a stab at it?
CAL .... by all means i have no insult intention .... often forum members miss the point .... in real life there is need for both ...small 50 w class A designs that actually rock .... or more power amplifiers like 250W that dont really need to be of a bandwidth of 200 khz and so on and on
i will not be the one to say which one is better but for sure there is need and use for both ...
the all question is about unic designs ( any way you slice it the QSC was unic ) no matter if good better or best
The question was posted cause i think that if NP thinks of designing something like that it will be trully inovative ( and from many aspects )
Steeve..... ADCOMS will not make it ....they may as well serve the creteria of power and quality but will not survive if abused ....
the question is yet again between the balance of protection methods and quality of sound while keeping the machine low cost and simple to make
there inovation is needed ....
other than that copies of designs of how an Adcom is working you may find a gozzilion
i expect if Np ever bothers with that it will be something magic not an updated version of a 555II
Sounds more like an insult to me.
Absolutely not Cal
Have you been sleepy and tired 😀
Lets look at what was said
"I wonder how innovative this could be"
To be insulting it should be like...."how innovative would that be"
Alone the use of "could" instead of "would" is a significant difference
The only insult might be the word "I wonder" 😀
Besides, Nelson reponded positively 😉
But innovative ?
Hmm...I wouldnt be surpriced if it would be a perfectly adjusted bootstrap design :rofl:
But it would certainly be innovative to have such design in our treasure box
Well, a long time ago I remember Nelson saying .."I dont do AB, I leave that to others"
And that could only mean his trusted ingeneers, right ? :smash:
Yeah, sometimes i remember what noone else barely notice 😛
