Amplify my 4 ohm speaker
Hello!
I'm new to all this amp stuff, and i hope this is the right section for this.
I've got a 4 ohm speaker, and i want to be able to plug my guitar in and get sound out of it. i dont really care about the sound quality, i just want a spare amp.
so where do i have to start then?
Try this one...it is good, it is cheap and it is easy to build and will match you
guitar needs...gain is adjustable to allow you to adjust is to your guitar output signal...can use simple power supplies or batteries (portable if you want)....nice, reliable, easy...match your needs as a beginner searching for something fast, easy, simple, good, reliable and so on.
Do not be impressed with watts...means absolutelly nothing..depends your speaker efficiency..some speakers can drive high levels of air pressure (sound) with 2 watts.... and you gonna have 6 watts RMS... and this is something alike 100 watts into the advertising (the way they use to say when sell portable units).... repeating, as we have our mind made by a terrible advertising brain wash of foolish beliefs..... this power is enougth to play loud..very loud!
Here is the link for the datasheet with all informs you may need...including schematic and informations about how to adjust gain and all needed stuff.
Need only to know what is a resistance, a capacitor and basic electronic assembling knowledges..the basic from the basic.
http://www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXutuqt.pdf
regards,
Build one LM1875 chip amp
If you goto Chip Amps forum, you can find stuff -> Search LM1875
Chip Amp is only one IC with 5 pins, and a few resistors and capacitors to add to the pins of the CHIP.
5 Pins:
input positive
input negative pole
output
V+ postive supply node
V- negative supply node
There are good descriptions how to build your IC power amp.
In forum and in internet.
Most use LM3875 but the circuit is very much the same for LM1875.
Here is one site about Gainclone = chip amplifiers:
http://myweb.tiscali.co.uk/nuukspot/decdun/gaincloneFAQ.html
Regards Lineup
No. Driving headphones is far less demanding than driving a speaker. Your headphones are normally 32 ohms and only need a few milliwatts to produce enough sound to make you deaf. For a 4 ohm speaker you need watts of power, so you need to have a power amplifier.
To be honest if you aren't up to building any kind of circuit then you are best sticking to a pre-made product. You can get amp cabinets that are designed to be connected to external speakers via a 6 1/4" jack. Do bear in mind that the speaker will need to be able to handle quite a bit of power for guitar use.
Do something like get a Effects pedal Kit that has gain and tone controll features and connect it to a TDA2003 or TDA2030/40/LM1875 power amp kit ......
There are alos a lot of really small guitar amps based on the LM386 chip like the Ruby or little gem ....
CHeers
A small AMP can be built with an IC some components and a power supply. Guitars can have a high output and this needs to be taken care off on the input side. Normal domestic amplifiers will not sound good and may fail.
You need an amp designed for a guitar. The next problem is the speaker. a hi-fi or ordinary speaker will probably be destroyed by the output of a guitar amp! One good strum will launch the cone across the room :bigeyes:
I would look at the practice amps on sale (used ones on ebay as well). For €40 it would be difficult to get all the parts including a case to make one.
:att'n: Please if you have never done electronics do not start with mains (220V) powered equipment :hot: . Let someone else have the hassle and provide safe equipment.:bigeyes: Any fault could provide full mains voltage to the guitar :yikes:
You see, the problem is that i dont want my guitar to be destroyed 🙂
but isn't there a premade thingie which i can put between my guitar and speaker, with the electronics already done, and which won't destroy my speaker after one nice chord ?
i'm really affraid ill screw up when im going to construct this thing myself 🙂
If the speaker is not designed for guitar use it will probably be damaged :hot:
One thing you have not mentioned is the power rating of the speaker. you need this value before you decide on an amplifier, this will be in watts.
I still think the referanced practice amp and similar (from @ €25 on Ebay) are a better buy
Edit, I recently built a 5watt stereo chip amp for my PC. Parts were about €15 + other things I had like case, sockets, mains connector, fuse holders, shrink sleaving etc, probably another €15 If I had to buy new.
