amplifier problem
that helps...if things are kind of sane, then there's a big negative voltage on the base of the right hand MPSA42. Also, probably enough sustained negative voltage that 470 uF cap may have been damaged, and you've probably exceeded the allowable Vebo for the right-hand MPSA42.
A few quick tests might help narrow this down...
What is voltage on base of right side MPSA42?
What is voltage across 1.8K in collector of left side MPSA42?
What is voltage across 1.8K in collector of right side MPSA42?
What is voltage across 1.8K in base circuit of MJE340?
