Amplifier loses stability on loading
The amplifier uses CFP Complementary Feedback Pair in the output.
CFP is known to cause instability.
The cure is to put small caps between B and C on the drivers in the pair.
Say 47pF or 100pF.
Any output topology can oscillate, there are various tricks to reduce tendency to oscillate, but make sure the overall compensation scheme and output network are sensible first. Faster output devices can give better performance, but you may have to tame their tendency to oscillate at RF with some base-stopper resistance or ferrites. The frequency of oscillation tells you a lot - high frequency is usually local oscillation within the output stage, and typically is dependent on the load and bias and amplitude.
And don't forget layout - poor layout can provide alternaitive feedback paths you didn't know you had!
The Sziklai composite contains a feedback loop. Two "fast" transistor in this configuration often oscillate. The slow MJL21193/4 and fast BD139/140 was stable in my experience, without any "healing" parts (EB cap of power tr.). MJL 3281 and 1302 and BD-s was instable without EB cap. With 1nF EB cap was stable, but non elegant and non sophisticated (only ready for use - as is)
Reactions: Patsaoglou
What about the Zobel?
No zobel was added!
The VAS device really ought to have current limiting
The enitial design was to use +/- 20V. The dissipation was around 180mw max.
I still did not completly understood why the FB cap had a small impact at the problem and the cap at the output completelly solved the issue!
I feel like the inductance of the trace in combination with the cap minimized the HF.
BTW the amp project is on: https://github.com/patsaoglou/BeatNTweet-Asma-l
The problem is most of the distortion in a 3-stage amp is from the output devices and is very load-dependent, which is why feedback is needed in the first place
There is local feedback, inherent in a follower (as it follows, LOL), probably less than 'active' feeback via a GNFB loop, but way faster!
I'm not sure if my preferential/personal dislike of GNFB or the fact it messes up the grounding (assuming I'm looking at it correctly) bothers me the most, but I do have some spare transistors, so after the current project and a bit more time in LTspice I might try the ultimate test - to build it and listen 😀
I did this in an SE tube amp and it added great space to the soundstage and 'unmuddled' the sound a lot, so I'm a bit curious as to how a BGT pseudo darlington would fare. I feel it shoudl be magnificent - but the reality could be anywhere 🙂
