i have two jl amplifiers. One xd 400/4 and one slash 100/1. Both on the same ground on chassis. Now the slash goes out randomly with a loud pop! Noise. Is this because i put them on one ground. Note:slash is the one farthest grounded to the point. Do i need to make different grounds to prevent protection mode?
I had trouble with a 2092 based amp popping, screeching and sometimes a siren type sound on power off.
It turned out it was due to having too much smoothing on the power supply.
I cured it with a small PIC monitoring the power supply and resetting the 2092 if the VCC voltage got too low.
