24, 2022 - 9:54pm
Hi All.
Yesterday I was listening at pretty loud level (according to Phone SPL meter 83db average with 87db peaks at distance of 9 feets from the speakers) and I did hear I belive "thumping" noise from the Low Frequency driver of my Sonus Faber Olympica 2 speakers only on the drum kick parts of the song (was playing Max-O-Man song by Fourplay on TIDAL 16bit/44khz).
I could see the woofer doing very long excursions but I'm not sure weather I was clipping the amp or was pushing the limit of the speaker. The amplifier is Primare I35 Prisma which according to hifinews can deliver 190W / 395W Continuous power (<1% THD, 8/4ohm) and 192W / 415W / 510W / 260W Dynamic power (<1% THD, 8/4/2/1ohm).
The volume control of the amplifier was at 70 out of 100 units. According to Sonus Faber user manual, the speakers can handle 50 – 250W and the Long-term max input voltage (IEC-268-5) is specified at 20 V rms.
So, does anyone have clue what is happening, am I clipping the amp or is it the speaker defective or is it the song having just to much low bass notes?
Hi All.
Sounds like there is some content below tuning (where the driver unloads) and it is flapping in the wind and bottoming out.
dave
dave
Put a sock in it translates to pushing the vent aperiodic. Dense open cel foam, polyfill, fibreglass, even filling the vent with drinking straws.
dave
dave
Thank you guys for your responses, but putting a sock into the port is not option with this speakers as the port is side reflex across whole speaker. Sonus faber call it STEALTH ULTRAFLEX whatever it means 🙂
If this is your speaker https://www.sonusfaber.com/en/products/olympica-ii/ I can see this happening because the woofer is small for the box size and maybe the whole back is a "port", leaving the woofer "unloaded"?? If your amp has a sub-sonic filter switch, be sure it is on. The speaker web site saz 40Hz so you want to remove anything below that. If you want 20Hz then you need a sub, which may also provide the filter you need for the main speakers.
I have a sub SVS SB-1000 but sadly i dont have crossover functionality on my primare i35 so i can limit the frequency on my mains
Actually I just realized the term is not clackiing i do not hear loud metal sound but bass distorsion. I belive the real word would be thumping sound. I will edit my original poat
- Amplifier Clipping or Speaker bottoming out?
