Amplifier Choice
Do I read the graphs correctly - 4 ohm speakers with ~ 85db sensitively? If the room is big, and you want loud, you will need more than a few watts. Some of these FirstWatt amps are not happy below 8ohm. Of course, my speakers are 6 ohm, and I have not noticed issues. My room is small.
My first DIY solid state amp was an Aleph J. One of the straight forward to build amps. Although the power goes down at 4 ohm speakers. Some of the amps get more wattage with lower ohm speakers, some less.
Your speakers are beautiful, but have you tried any other amps with them? You might get an idea of how much power sounds good, to you, in your room.
Here is Mr. Pass’s summary of his amps. Most are available for DIY, all the ones not in current production. Yes, Mr. Pass is very generous with his talent here.
FIRST WATT PRODUCTS
