One type of antenna always worth a try (almost free). Take an RG59 or RG6 patch cable. Cut off one end. Strip off the outer shell and braid 3 ft from the cut end, so that just the solid core and insulator around it remain. Form the stripped end into a circular loop, secure with tape, and hang the loop high, in a window, etc.
Another tip: the best antenna amplification I have ever had was with a 10db amp sold as a cable splitter buffer. Seemed to give a perfect S to N balance for better reception. All other antennas or amps with 20db or higher gain didn't work as well for me.
