Hi, I think there may be sonmeone could help.
My Carver TFM 15CB has 1 channel dead
The TFM15CB has built-in passive preamp (which I believe it can be bypassed ). When having jumped the signal( routing the signal directly from input socket to the amp CB), I forgot to turn down the CD player output level. The result is the sound is VERY loud. I had to stop the CD player immediately.
When I jumped back the signal route as original, there is no sound on BOTH amp channels. Leaving it for about 3 hour ( still in original state), turn it on, there is only ONE channel work ( the LEFT one)
I don’t know what happen to the power section. I think the too- loud signal hurt something in the CB
Dose anyone encounte this problem before?
I still have a nother Carver with the same model ready for mono bridged. What should I check?
Please give your advice
http://i24.photobucket.com/albums/c48/JULIOVO9999/Modem/InsidePreandPower1.jpg
http://i24.photobucket.com/albums/c48/JULIOVO9999/Modem/Inside2.jpg
Hi
May be no one could help.
It makes me more confused when I mono bridge the amp, it works perfectly.No problem at all
Please help
Please help
Looks like the preamp is just pots, so it's probably just a bad pot on that channel... when bridged the signal only goes by the working channel and it's OK.
Without seeing a schematic it's tough to be sure
First thing is to find the schematics for your amp. Looks like this web site has it: http://www.thecarversite.com/manuals.htm
Once you have the schematics and post it somewhere to be available then I am sure that many members on this forum could help you.
Good luck, Peter
Good luck, Peter
Thanks for your idea. But as I said it worked perfectly, it is true. I have a nother amp ( the same model: TFM15CB). Having made a blind test in bridged model, I found that the 'problem' amp sounded even a bit louder than the normal one. That made me confused
I also found the website address to down load the schematic. But it is a bit difficult to read due to poor copy quality. I still tried to find the way to post it on.
the schematic was downloaded from www.thecarversite.com after registering
Joined 2002
have you taken the board out that holds the 2 pot ? Maybe give them a quick solder job ? They are probably used lots ( ie turned up and down ) so a cold solder could effect this.
J'
J'
J'
Hi, I did check the preamp board. It is working. Now I have just bought a preamp, plug it directly to the amp, still 1 channel sound. I think the power section has problem
However, it made me mad when mono bridge the amp, it still sound percfectly😕
Joined 2002
If one channel is not working then when you bridge it, there will be no difference.
I'll ask some questions,
So both channels actually work ?
when you change the cable from the front board a to be or b to a, vice versa they both work when testing them ? with the good one..
Jase
when you change the cable from the front board a to be or b to a, vice versa they both work when testing them ? with the good one..?
Jase
Hi Jase
A test was made with the good amp ( plug B to A vice versa). The good amp work perfectly in stereo and in bridge mode).
When being bridged, ( both amps are in original condition. That means thers is no mod here: the cable B in B position, and cable A in A ...no change at all) I can say that the good and the 'problem' amp sound identically. The 'problem' amp sound abit lounder than the good ( but not significantly)
That is why it made me confused
In theory, the 'problem' amp must sound less lound than the good due to having 1 channel dead
Joined 2002
- Amplifer 1 channel dead .Please help
