So i assembled my amp6 and tested it with bad resoults. I can hear a very silent constantly ticking sound from one of the speakers connected, but thats all. There's no music, what is wrong? Cable and source is working properly.
https://imgur.com/Ez8cira
https://imgur.com/AZDrdQc
Thanks alot! You just saved the festival for 15 ppl. 🙂
But the sound is very quiet actualy. Any ideas?
Hm, seems like this is the problem.
"The sound is weak from one channel."
Check if there is a 12V voltage offset on one output. In that case, an output
transistor is probably damaged and the chip needs to be replaced."
Gotta love those ta 2020 chips.
Now.. your challenge is to source a Genuine Tripath replacement chip.
G'luck, as those are rare.
41hz still sells 2020 chips. I assume they are old stock, likely produced before Tripath went under.
