I've finished an AMP4 but I was less successfull than with my AMP6...
The amp is not working. I was suspicious since the moment I tried to adjust the offset : the voltage was not measurable.
I tried to connect a source and speakers and as I expected, nothing happened...
So, I tried to figure out what was the pb. Since I don't understand a lot in electronic, this is not easy.
First, I got 5v at J4 pin 7 and when I close J4 pin 5 and 6 (to unmute) the relay is closing. So this part of the circuit seems to work.
Then I checked the diodes. The diode on pin 7 is on and the HMUTE turns of when I unmute the amp. All the other diodes stay off. So, this is correct also.
Nothing is going hot.
I tried to figure if there was a short circuit somewhere. I used the continuity test.
And i don't understand the results! I have a short cut somewhere!
I got continuity when testing between the pins of C10, C22, C24, C35 and C100 or C101. And this makes that I also have continuity between pins 4 and 5, 6 and 7 etc. on the chip.
I also noticed that when measuring D1 on the board (can't find it on the schema), I got 0,6V in one way and 1,9V the other way. D1 is soldered teh right way.
So, can someone help me?
Please, HELP !
Please, HELP !
What chips are used in the AMP4? I know one is the TP2050 output stage chip, but what is the other one? The TC2000? And which chip are you talking about in your above post?
Have you soldered the chips in the correct way? I've made that mistake on an amp3 kit once...
the chip is the TP2050 associated to the TC2000 as you stated.
I am speaking about the TP2050.
In the document from tripath, in the schema, the caps I'm speaking about are Chbr (.1uF) which are Vcc and the ground. The document is here : http://www.tripath.com/downloads/TK2050.pdf
the C100 and C101 1500uF are stiffener caps which have been added by Jan.
The chips seems to be soldered the right way.
There are some earlier stage pics here : http://blog.niiico.org/index.php?2006/10/17/56-amp4-un-ampli-2x30w-a-base-de-tripath-ta2050-tc2000
Clic of the pics to enlarge them.
niiico said:I tried to figure if there was a short circuit somewhere. I used the continuity test.
Ok, thanks for the explanation and deatailed, focused photos! From what you're saying you have a short from power to ground which is not good. Is it a dead short (0 ohms) or is it something else? I would also check the diodes on the bridge rectifier to make sure they're ok.
I don't know what the purpose of D1 is because I can't trace out the connections on the board and it isn't part of the Tripath schematic. Jan added this for some reason.
Nicolas,
You have a shortcut between Vcc and the ground. You have to find out whether the shortcut is from power supply or from TP2050. I think that this can be checked by removing J10 (it disconnects power supply). If this is on the power supply side, check C59 (or C50). I think that this is SMD cap and it may be incorrectly soldered. You can also remove R6 just to be sure that it's not due to C50 or Q10. If the shortcut is on TP2050 side, any of C10, C22, C24 or C35 may be incorrectly soldered (or there is a shortcut under the chip, which would be the worst case to fix).
But also let me know whether you have +5V power supply because if you have a shortcut, you shouldn't have any voltage on the board - and this is strange.
Also the masurement of D1 is very strange. How can you have two different voltages? Are you using a voltometer or an ohmometer? I'd say that with voltometer your mesurements are not possible.
Edit: I just noticed on your pictures that J10 is not connected. Is it because of the shortcut?
Marek
Marek
I have +5V. This is what I found strange.
It maybe because of the tester I use. There is almost no user manual and there are some odd measures.
No, the pictures are from an earlier build stage. The amp wasn't finished. On this pictures, only the smd are soldered and the j10 an j5 are not.
I'll make some new test ASAP following your hints and I'll see what happen.
I'll post also some up to date pictures.
Thank you for your help.
Some news...
Jan explained that it may be my power supply which wasn't high enough (only 12V for testing), even if I was earing the relay click.
So, I took my AMP6 transformer (15V) and try. And I have some "almost" good news : I got something!
For the 1st time I got some offset measured by a voltmeter at the output.
One of the channels is reacting well to the offset trimmers (POT1 and POT2) and the other has an odd behavior.
The first can go from -250mV to +150mV while the other goes from -250mV to 0V and nothing else. I put 'em both to -1mV.
So I tried to connect it to some old speakers and my powerBook. I got the channel reacting correctly to the trimmer playing music and the other no...
I turned the trimmer to go back to something like -150mV and I got some music, but with an horrible hiiiisssss (which seems normal with this offset)
The other bad point is that the "thump" in the speakers when the relay goes on and off is very loud.
So, I think we are on the right way, but I still need some help from you 🙄
Some pictures of the amp:
But this would mean that all your information about short circuit on the board was not correct
. How did you test it?
Marek
Marek
You're right. I don't understand.
I made some new tests yesterday and realized something I didn't understood.
If I test continuity from ground to power, I get it. If I reverse the pins of my tester (testing from power to ground) I have no continuity.
Can't say why. 😱
Sorry to make you work for me the wrong way...
I had an old 10$ tester before to by a bigger one, but I wonder if I shouldn't use the older one?...
Can't say why. 😱
It looks like a problem with the tester rather and not with the amp. Just buy any cheap multimeter with continuity tester - I don't think that it will be more expensive than 20$. It will save you a lot of time .
If you have +5V and VCC on the board, there is not short circuit (at least between VCC and ground).
Marek
Marek
But still - don't give up. First check that you have correct power supply voltages (if you use correct power supply).😀 . Then, confirm the issue with hiss in one channel. This could suggest a problem with output stage of the channel being incorrectly soldered. Maybe Jan could give you some advise in this case.
Marek
Marek
Markus2006 said:But still - don't give up. First check that you have correct power supply voltages (if you use correct power supply).😀 .
For the supply, I'm sure it's ok, I'm using it with my AMP6 and it is working per-fec-tly! 😉
I've got to look at the schema since the trimmer on the bad channel is not reacting the right way.
I'll keep you in touch 😉
I put the iron on every pin I found to remake the solders.
I tried again and failed.
The channel 1 is not working correctly. The trimmers allows me to null the offset but it nulls also the channel. when not null, there is a clipping noise (I think it is that, I never heard an amp clip! It's like a switching hiiiisss) on the channel 1 and it is independent from the volume. If the volume goes up, I can hear the music behind the noise and the noise level stays stable.
I have a thump on both channels, but on channel 1, it is very strong when turning both on or off.
BTW, the OVRL diode is on and not switching. And when I turn off the amp, the noise is going more and more in the trebles until the relay opens.
That's all I got. 🙁
Oh, no, I forgot : channel 2 is perfectly working.
Waiting for Jan advices...
That's all I got. 🙁
The thump is caused by DC offset. If you can't properly adjust the DC offset on channel 2 then you should be looking for poor solder joints (although you said you already reflowed every pin); particularly on the input circuitry. It wouldn't hurt to check to make sure that the adjustment pot is good as well. Make sure you have the correct parts in the correct places on the channel 2 input circuitry. From your pictures I can see that R54 is missing. Is that part not necessary?
What is the OVRL diode?
The OVRL is for overload. it works normally. And R54 isn't mandatory.
Jan suggested me to verify the soldering of the output filter toroids : a cold/bad solder may cause my problems...
I may also recheck the input circuitry...
I'll try this and post the results.
So you're saying the overload light is lit? That should give you some clue as to the nature of the fault.
For the other Tripath chips that means the input is overloaded. Definitely check the input circuitry. Check the DC bias on the signal inputs. It should be around 2.5V.
How do I check the DC Bias on the input?
And how to verify the trimmer is alright? Should I measure it like a resistor to verify it is 0 Ohm in one extreme position and 5K in the other one?
niiico said:How do I check the DC Bias on the input?
Open up the TK2050 datasheet and go to page 4. You'll be probing around the TC2000 chip with the power on so be extra careful not to short neighboring pins. With your multimeter set to measure DC voltage, measure the voltage between pin 1 and ground. You should see about 2.5V. Next, measure the voltage between pin 15 and ground. You should see about 1.2V. Next, measure the voltage between pin 23 and ground. It should be about 2.5V. You should see the same thing between pin 28 and ground. Let us know if any of those voltages are wrong.
niiico said:And how to verify the trimmer is alright? Should I measure it like a resistor to verify it is 0 Ohm in one extreme position and 5K in the other one?
Exactly. With the power off, measure the resistance between one side of the pot and the wiper pin. Just make sure the pot's resistance varies as it should when you adjust it with a screwdriver.
so, I have 2,56 V on pin 1, 1,27V on pin 15, 2,63 on pin 23 and 2,63 on pin 28.
Everything seems correct.
The trimmers react oddly... They both react the same way. But it may be my Ohmmeter which makes me some tricks one more time. I got 0 Ohm at one end, then it goes up and reaches 1,5 KOhms before to go down 0,5 KOhms. As they should be 5K pots, I'm not sure they are good. But since they react exactly the same way...
I hadn't time to re-melt solders. Next post.
- Class D
- AMP4 not working, HELP!
