Amp with Bluetooth DSP control
I'm looking for an amp or even crossover/dsp with bluetooth control for a subwoofer similar to SVS system. So convenient to dial in dsp from the mobile phone as you change seating positions and set preset eq.
Is there an amp or dsp that does this?
Thx
Also consider a raspberry pi with a Hifiberry dac+dsp - you can load their Hifiberry OS onto the raspberry pi and get full parametric EQ controllable via a mobile friendly web UI and feed the output into any 2 channel amp. Moode with raspberry pi is another option that works with various Dacs and has Camilla DSP built in for maximum flexibility. Again, web UI.
