amp using tda7250 driver ic?
I have seen this page with a circuit layout for 2x130w into 4 ohms
http://home.eunet.cz/rysanek/cheapamps_en.html
I was then thinking about if it is posible to use the circuit with higher voltage (the the Tda7250 can be used with up to 90 v) and use maybe MJ15024/23 or BUZ900D/905D
http://www.semelab.co.uk/magnatec_mosdata.htm
to get a low cost amp of about 2x200w into 8 ohms on a single pcb.
I know that it's not a high end sulution. I just need low cost high power.
any advice is welcome. JC DK.
OK, here is a very simple idea: http://www.delphion.com/cgi-bin/viewpat.cmd/US05029299__ Items 34,36 are the main filter caps.Note that what is normally grounded, ie: the center tap of the transformer, is actually the 'hot' output of the amplifier and that the outputs of the amp drive what is normally 'ground'.For 200W RMS at 8 ohms you will need a pair of 3,300µf(or larger)80V(or higher)caps and a 100VCT(50-0-50)400VA transformer and only one pair of BUZ900D/905D.These are item 44,46 short out 48,50 and 28,30 are not used.Items 58,62,64,76 are 1N4004 type diodes.Items 70,72,80,84 are 1N4744 15V 1W zener.The ratio of 39/42 sets the gain of the amplifier.Items 68,74,78,82 are 22µF+.1µF 25V and add a 22µF 100V to 34,36 while you are at it.Items 56,60 are 3.3K with 52,54 changed to 330 ohms and a 2K bias pot added across what is shown as the bases of 44,46(the BUZ parts).The BUZ will need 220 ohm gate resistors.Note that the cases of the BUZ outputs are at ground potential and need no performance robbing insulators.This is not a new idea.The TransNova series of amps from Acoustat/Hafler/Rockford are all built this way.Items 22,26 are 3.3K 2W (a bit hot, or 5W if you want them cold).Item 66 is 1K 5W.Add flyback diodes to 44,46(and 10V gate zeners if you want them)and don't forget the output zobel of .1µF+10 ohms.A NE5534 works great as the driver IC.
