Most speakers, even the good bookshelfs won't go below 40 to 50 Hz and audio goes down to 20Hz. Smaller the speaker, lower is the bass response.
Gajanan Phadte
Gajanan Phadte
if your amplifier ( or Laptop ) has dsp with crossover , set the sub to do below 80-100hz choose what sounds better to you , that will relief the woofer from lowbass and improve midbass.
I am more interested in your thoughts on the Amp? is it better to get a designated audio amp? Also what do ye think of the speakers?
For 40$ i would buy it for sure , the speakers for the price (10$) are ok , but they wont do low bass.
If you want to get low bass you will still need a active subwoofer (with it´s own amp).
For what i´ve seen in the manual you can have 2 sets of speakers + 2 surround + center + sub connected to that amp , so all you need to go is the active sub.
that amp as lots of possible configurations , if you have the active sub one thing you can do is keep the bass level at 0 (unchanged) that will relief the main speakers from heavy bass , on the active sub amp you can then choose the level of bass and the crossover frequency
