My first, small question!
I've read the specs of some amp kits that say something like +/- 35v supply and then specify a 25+25v Toroid.....while another is +/-59v and a 40+40 toroid. How does this work, how do you work out the transformer voltage to the amp voltage...I expected to match them but that doesn't seem to be the case......
1.41
Hi Xicarius and a warm welcome
You'll probably find an answer in this small thread:
http://www.diyaudio.com/forums/showthread.php?postid=14362
Feel free to ask if you have more questions.
/Hugo
/Hugo
Re: 1.41
Thank you! So, I multiply by 1.41, then subtract a couple of volts for losses in the rectifier? Interesting. Thanks for that.
Netlist said:Hi Xicarius and a warm welcome
/Hugo
