Hi. I have been away so long that did’nt remember my sign in info. So created new.
But here is my question. I have Technics SU-V900 power transformers, filter capasitors and heatsinks. Transformers secondaries are about 46VAC, so that makes quite high voltage after rectified and filtered. Caps are 12 000uF/71V
Do you have suggestion, what could be quite simple power amp schema for these voltages. I have found something, but don’t know how they sound.
I'd suggest that those voltages would probably be more suited for a Class D amplifier.
You might find a Class AB design but that would be hard work on the output devices.
Tons of amps working with +/-65V rails, think typical 200/8 or 300/4 power.
Simple, good, reliable and well proven, search for Apex Audio designs in this very Forum.
Lots of data, successfully built by many, designer is here answering doubts, what´s not to like?
