ok, with power, the amp is drawing too much current and some of the chips are getting very hot, i put some things back in the wrong spots. be easy on me, its my first amp repair. heres the video. please watch the whole thing and let me know what you think. thanks. need any other info, please ask.
blown amp - YouTube
blown amp - YouTube
UPDATE. ok, there were 4 TIP35c's so the 35c's went on one side, and the 36c's go on the other, can someone tell me which side goes where?
I would check the output mosfets first and replace where necasary.
If the chips still get hot then one or more might have fried.
Had a similar problem on 2092 based system and the mosfets frying took out the 2092 too. Replaced both and teh amp was fine.
are you talking about the N0506 mosfets? or the TIP35/36c's?
I would check both.
