Amp Question
Use both scope channels. One probe on the leg of an output transistor that connects to the output filter inductor. The other probe on the rail voltage (rectifier output leg). See video attached.
http://www.bcae1.com/temp/ampstartup01.mkv
If the 1405s failed, at the very least, the protection circuit wasn't sensitive enough to shut the amp down before the PS FETs were damaged. Under stress (amp hot, shorted speaker, shorted output...), the 064s would likely fail where the 1405s might survive.
Ok I’m still going through this amp .
Out of 5 banks of outputs 2 banks survived.
Wondering could I use these outputs that survived in 2 of the banks or should I toss them all and order all new ones ?
When measuring them all of them read 2.5M ohms from drain to source
