Having a sort out, job lot, so here goes:
All new and packed - unused items
OP-AMPS
BB OPA1642 x10pcs SOIC
BB OPA2211AIDDA x10pcs SOIC
BB OPA1611AID x10pcs SOIC
NATSEMI LME49710HA Military metal package x4pcs
NATSEMI LM4562MA SOIC x4pcs
NATSEMI LME49720HA Military metal package x4pcs
AMP-DRIVERS
NATSEMI LME49811TB x4pcs
NATSEMI LME49810TB x4pcs
USB-DACS
TI PCM2704JTG4 audio dac w.USB 32tqfp x4pcs
OUTPUT-TRANSISTORS
ON-SEMI MJL21195G PNP 16A T0247 x2pcs
ON-SEMI MJL21196G NPN 16A T0247 x2pcs
ON-SEMI NJL3281DG THERMALTRAK T0247 x4pcs
ON-SEMI NJL1302DG THERMALTRAK T0247 x4pcs
ON-SEMI MJL21193G T0247 x2pcs
ON-SEMI MJL21194G T0247 x2pcs
FULL-AMPLIFIER MODULES
TI TAS5630DKD2EVM 2x300w PUREPATH AMPLIFIER Rev.A
NAP-140 clone kit with all components unassembled (from ebay) 2x80w
POWER-SUPPLY
SMPS 50v 7.3A ~375w (BNIB) Approx WxHxD 3"x2"x9" (good for testing TI amplifier???)
Rectifier diodes 10A10 x10pcs
Nichicon Gold Tune 5600uF 50v x4 PCS
PCB
PANSON AUDIO initial driver board r1.32 x4 pcs
PANSON AUDIO LME4981x Compact amp board x2 pcs
PANSON AUDIO initial power board r3.2 x2pcs (npn/pnp)
PANSON AUDIO initial power board r2.2 x2pcs (thermaltrak)
PANSEN AUDIO reservoir two PSU board x1pcs with terminals
AudioWind SP-5 PSU PCB x4pcs (diode rectifier/snubber + 4 bulk placement)
XY HiFi v4.0 PSU PCB x2pcs (rectifier/snubber + 4 bulk & Led's placement)
CHASSIS
Aluminium DAC chassis black unused (ebay) WxDxH 184mm*286mm*60mm
Chassis is new and mint - make an amp or something with it?
That's all folks, so, open to offers - have a think and make me an offer
Best of luck and thanks for looking
OP-AMPS
AMP-DRIVERS
USB-DACS
OUTPUT-TRANSISTORS
POWER-SUPPLY
PCB
CHASSIS
