Amp noise !!! Please Help !!!
Hy !
I have a big problem:
I built from scratch an amp based on the TDA7250 and TIP142/147.
I have found a transformer that i have rebuild to get 32-0-32 and 11-0-11. I have rectified the 32-0-32 trough a 25 amps bridge and filtered trough 2 x 10000 Uf caps. I got 44-0-44 V
The 11-0-11 is rectified trough a 5 amps bridge and 2 x 4700 Uf caps.
Now from the 44-0-44 i feed the amp and from the 14-0-14 (rectified) i feed a computer cooler and a LM1036N tone control.
I have put all in a case and it looks pretty good. It sounds great but . . . . i have a very loud noise with the cooler on. With the cooler off i have the same noise but smaller.
What can i do to get rid of the noise and enjoy my amp ?
Thnaks in advance.
Make sure that your main ground is not where the filter capacitors connect together! Also, sometimes a star ground is not the best solution when something dirty, like a fan is connected there. It is best to connect all sensitive circuits to one star ground and then the noisy stuff to another star ground. A pigtail from the junction of the reservoir capacitors to these two stars completes the circuit. The chassis, by the way, should be connected to earth on the mains side. It is optional to join the circuit ground to the earthed chassis.
Hope this helps and good luck with your amp!
The main ground of the amplifier is conected where the two large caps get together. The ground of the tone control is the same as the amplifier for the in and out ( signal ) but the power ground of the tone control is connected together with the ground of the fan where the 4700 caps go togheter.
Can somebody describe me a better grounding scheme for my setup ?
