Hello..
I am designing an vibration machine for industrial, and looking for RMS 600W < digital amp module.
Frequency : 3 ~ 100 Hz .
It generates only sine wave, so the sound quality doesn't matter.
The stability and power is important.
What would you recommend for that usage?
Frequency : 3 ~ 100 Hz. It generates only sine wave The stability and power is important.
What kind of voltage and current are needed? Audio amps are rated into 4 or 8 Ohms resistive.
Most audio amps would be thermally limited here if you are running sine waves as input and not music.
/U.
/U.
It's up to design, which will be 4 Ohms. Voltage would be 60.
Hello..
AUD600 will support 1Hz signal
my one customer used and tested for medical mixing unit(vibration 1Hz to 100Hz)
MANOJ
