amp clipping and shuttingdown
😕hi everyone.trying to solv a problem.with a ampeg ba600 amp clipping and shutting down.customer sayes he has to flip power switch on/off to get amp back on. he uses a pick to play with and i use my fingers.i have not been able to make amp shut off. any suggestions??????? help please. this one realy bugging me.
bill g audiolabs
i've seen a few Ampegs that shut down from excessive output tube current caused by the grid connection inside the tube being intermittent. once you hit the right note at a sufficiently high volume, the grid connection vibrates loose, the tube goes into a high conduction state, and the bias current sensing circuit puts the amp into protection. while the connection is vibrating loose, there's a short burst that sounds like hard clipping before the protection kicks in.
oops... my mistake, this is a class D amp, the only tubes are in the preamp.....
still, there may be something vibration sensitive in the amp (vibration caused problems are common in combo amps) or power supply. especially check the soldering on any connectors and headers on boards, and any large components like high wattage resistors, output devices, etc...
